Date/Time: Fri, 20 Sep 2024 02:37:25 +0000
Ray drawing tools moves after SC restart?
View Count: 924
[2014-09-15 17:28:27] |
bwalks123 - Posts: 122 |
I have been drawing Rays and lines which seem to adjust/move after reopening a chartbook or restarting SC, it seems to only happen when I use the "Copy and Move Drawing" on a ray or line? I am currently using SC version 1174.
[2014-09-15 17:34:55] |
Refer to this help topic: https://www.sierrachart.com/index.php?page=doc/helpdetails34.html We cannot provide any further help on this and there will be no further comment. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
