Date/Time: Tue, 22 Apr 2025 23:29:53 +0000
Incomplete DOM
View Count: 221
[2024-12-31 00:57:49] |
Slidgio - Posts: 4 |
Whenever I open up the trading DOM for my stock charts, I get an incomplete buy and sell numbers. Well not necessarily incomplete more like theres only one buy order number and one sell order number on each side. I have put in some examples, one is the default and the other is a more customized DOM
Attachment Deleted. ![]() ![]() |
[2024-12-31 17:39:34] |
Sierra_Chart Engineering - Posts: 19306 |
For market depth data, you need to use NASDAQ TotalView data: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes Otherwise, there will not be any market depth data. However, you have to pay for real-time NASDAQ TotalView data to receive market depth data from NASDAQ TotalView. And to access NASDAQ TotalView data, you need to follow the instructions below: Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-12-31 17:42:59
[2024-12-31 19:09:15] |
Do I have to use the Denali Exchange Data Feed? im on IQFeed. So don't I have to purchase NASDAQ total view data on IQFeed?
[2024-12-31 19:22:49] |
Market depth data for stocks through IQ Feed is not supported by Sierra Chart.
[2024-12-31 19:52:30] |
ok thank you for your help
[2024-12-31 20:00:00] |
You can get market depth data using the NASDAQ TotalView data from the Denali Exchange Data Feed: Denali Exchange Data Feed: Nasdaq TotalView Data Feed Notes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-12-31 20:00:26
