Date/Time: Tue, 22 Apr 2025 23:29:54 +0000
ES symbol settings MBO
View Count: 121
[2024-12-30 21:58:19]
User507822 - Posts: 3
Hi im trying to switch the ES mbo to only show 50 and above but i cant find the right symbol on the symbol settings. Can you tell me which one it is?
[2024-12-30 22:29:53]
John - SC Support - Posts: 39428
The exact symbol will depend on what service you are connected to. The easiest way to determine this is to open your "File >> Find Symbol" window and find the particular instrument you are wanting. The main entry for that instrument will be in the format of what the Symbol Settings is using.
For instance, if you are connected to "SC Data - All Services" and on the Find Symbol window you open the section for "Futures - CME", you will scroll to the entry for ES which shows as "ES?##-CME". That is the symbol setting you need to change - ES?##-CME.
