Date/Time: Tue, 22 Apr 2025 23:29:53 +0000
Sound Alert Symbol Name + WAV?
View Count: 127
[2024-12-30 16:12:04] |
Poblano Trading Capital - Posts: 18 |
Hello SC Team, Is it possible in the alert configuration sound to add the symbol name from the alert window and the personal .wav sound? For example, if there is an alert on the SPY chart, I want SC to tell me "Alertsound.wav" + "SPY" So I don't have to look at the Alert Manager and see the chart # / symbol alert. Thanks for your feedback. |
[2024-12-30 16:43:01] |
John - SC Support - Posts: 39428 |
You can create your own sound files that can be used with Alerts. These files are stored in the "AlertSounds" folder under the main Sierra Chart installation folder. There is also a text to speech option in the Alerts that you can setup. Refer to the following: General Settings Window: Text to Play When This Alert Triggered (Global Settings >> General Settings >> Alerts >> Alert Settings) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
