Date/Time: Tue, 22 Apr 2025 23:35:06 +0000
candle chart on a subgraph
View Count: 119
[2024-12-30 07:44:30]
SafSaf - Posts: 126
alright lads, is there a way i can place a candle chart on the main window and duplicate the chart so it also appears on a subchart where i can add an indicator to it so, in essence, i have a naked candle chart and the same chart below it with an indicator. i don't really want to duplicate the chart into another window if i can help it. tia
[2024-12-30 12:08:19]
Sébastien - Posts: 58
You can do that with the Study/Price Overlay study :
https://www.sierrachart.com/index.php?page=doc/StudyPriceOverlayStudy.php#s118
[2024-12-30 14:40:57]
Sierra_Chart Engineering - Posts: 19307
Use this study to do this:
Overlay - Bar
It will just reference the same chart.
Set the Chart Region setting to the region you want it to display in.
Date Time Of Last Edit: 2024-12-30 14:41:09
