Date/Time: Fri, 20 Sep 2024 02:41:38 +0000
Values not showing in Region Data Line
View Count: 1287
[2014-09-15 17:10:23] |
traderderic - Posts: 3 |
I have checked the Subgraph boxes for displaying name a values globally, in the chart values window, and in the region data line, but the values are not showing. Please see attached for explanation of where I want the study values to show. Thanks.
keltner.GIF / V - Attached On 2014-09-15 17:07:55 UTC - Size: 52.81 KB - 354 views |
[2014-09-15 18:24:58] |
You will not see them on the status bar. Refer to the documentation here about the Chart Values window: https://www.sierrachart.com/index.php?page=doc/doc_Tools.html#ViewingToolandChartData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-15 19:30:24] |
So using a separate window is the only way to view indicator values across a chart? That's a bit inconvenient.
[2014-09-15 19:58:09] |
Yes. You can use the Tool Values Window or the Compact Tool Values Window. Longer-term the Status Bar will be removed.
