Date/Time: Sun, 04 Oct 2026 19:15:23 +0000
Accessing all horizontal lines on a chart for all symbols
View Count: 632
[2024-12-29 17:14:03]
sean3000 - Posts: 65
I'm trying to access all horizontal line drawings on a chart, including for symbols that are not the currently displayed symbol.
GetUserDrawnChartDrawing() seems to only return drawings that match the current chart's displayed symbol.
Example:
1. Chart 1 currently displaying NVDA with a horizontal line at 141
2. Chart 2 currently displaying MSFT with a horizontal line for NVDA at 139
When using GetUserDrawnChartDrawing() on Chart 1:
- Returns the 141 line since chart is displaying NVDA
When using GetUserDrawnChartDrawing() on Chart 2:
- Returns nothing, even though there is an NVDA line at 139
As a workaround, I'm using GetUserDrawnDrawingByLineNumber() and looping through a large range of negative numbers like -1 to -9999. This is inefficient but will find all lines regardless of which chart/symbol is currently displayed.
Is this intended behavior of GetUserDrawnChartDrawing()? If so, is there a way to access all drawings across charts besides iterating through line numbers?
[2024-12-30 01:24:08]
Sierra_Chart Engineering - Posts: 25051
In the charts that you are accessing from ACSIL regarding Chart Drawings, make sure this Chart Setting for those charts is set to Yes:
Chart Settings: Show Chart Drawings For Different Symbols (Chart >> Chart Settings >> Chart Drawings menu)
Otherwise, there is no solution. The behavior you see is as intended.
Date Time Of Last Edit: 2024-12-30 01:24:37
