Date/Time: Fri, 14 Mar 2025 12:36:06 +0000
CTS T4
View Count: 123
[2024-12-29 14:43:29] |
User990841 - Posts: 1 |
Good Morning On CTS website they say they are compatible with sierra, is this the case? can I use my T4 for real time data for sierra? Thank you |
[2024-12-29 18:48:39] |
Sierra_Chart Engineering - Posts: 18778 |
CTS T4 is no longer supported by Sierra Chart. But Cunningham does support the Teton order routing service: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
