Date/Time: Tue, 22 Apr 2025 18:36:23 +0000
how to find entry price on spreadsheet
View Count: 127
[2024-12-28 23:22:19] |
User970210 - Posts: 100 |
Hi, how to find entry price of open position on spreadsheet? thx Song |
[2024-12-30 14:52:13] |
John - SC Support - Posts: 39418 |
On the Spreadsheet System for Trading is an item in Columns I/J for "Last Entry Fill Price". This will give you the fill price for the last order that was put in and filled. This is different from the Position Average Price, as it is only the last filled order. Refer to the following: Spreadsheet Systems, Alerts and Automated Trading: Last Entry Fill Price [J48] There is not way with the Spreadsheets to get each of the fills, if you are needing them for multiple orders that make up a position. To do this, you would need to create a Custom Study. Refer to the following: Automated Trading From an Advanced Custom Study https://www.sierrachart.com/index.php?page=doc/SierraChartStudyAndSystemProgrammers.php For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-02 21:20:51] |
thanks for your reply. does entry price is automatically recorded in spreadsheet study too? Song |
[2025-01-03 15:11:36] |
That field (Last Entry Fill Price) is only available in the "Spreadsheet System for Trading" it is not available in the standard "Spreadsheet Study".
[2025-01-03 16:01:54] |
does spreadsheet system for trading only record last fill entry price for the system or it can record live position from manual or other trading system? Song |
[2025-01-03 16:11:05] |
It is whatever the last entry price was, regardless of how that entry was done.
