Date/Time: Fri, 20 Sep 2024 02:46:51 +0000
Items doesn't work - no active
View Count: 948
[2014-09-15 16:02:31] |
F23TRADER - Posts: 2 |
About 90% of the menu options (including the options menu in the top bar) is not active - not to click?
[2014-09-15 16:44:15] |
Have you opened a chart through File >> Find Symbol? Here are the instructions to get started with Sierra Chart: http://www.sierrachart.com/index.php?page=doc/doc_GettingStarted.php#ConnectingtoData Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
