Date/Time: Wed, 16 Sep 2026 09:58:19 +0000
John Ehlers Deviation Scaled MA Code
View Count: 1283
[2024-12-28 14:11:59]
cmet - Posts: 742
This is a version of the Deviation Scaled Moving Average by John Ehlers. If any ACSIL experts have time, was hoping you could look at the code below and give any comments/criticisms.
The PDF of the DSMA from Ehlers which contains the original code is also attached for reference.
Thanks in advance for any help.
#include "sierrachart.h"
SCDLLName("DSMA");
SCSFExport scsf_DSMA(SCStudyInterfaceRef sc)
SCSubgraphRef Subgraph_DSMA = sc.Subgraph[0];
SCInputRef Input_Period = sc.Input[0];
SCInputRef Input_Data = sc.Input[1];
SCInputRef Input_StdDevs = sc.Input[2];
if (sc.SetDefaults)
sc.GraphName = "DSMA";
sc.AutoLoop = 1;
Subgraph_DSMA.Name = "DSMA";
Subgraph_DSMA.PrimaryColor = RGB(0, 255, 0);
Subgraph_DSMA.DrawStyle = DRAWSTYLE_LINE;
Subgraph_DSMA.LineWidth = 2;
Subgraph_DSMA.DrawZeros = true;
Input_Period.Name = "Period";
Input_Period.SetInt(40);
Input_Period.SetIntLimits(1, MAX_STUDY_LENGTH);
Input_Data.Name = "Input Data";
Input_Data.SetInputDataIndex(SC_LAST); // Includes standard inputs
Input_StdDevs.Name = "Standard Deviations Multiplier";
Input_StdDevs.SetFloat(5.0f);
Input_StdDevs.SetFloatLimits(0.1f, 100.0f);
return;
// Variables
float a1, b1, c1, c2, c3;
SCFloatArrayRef Zeros = Subgraph_DSMA.Arrays[0];
SCFloatArrayRef Filt = Subgraph_DSMA.Arrays[1];
SCFloatArrayRef ScaledFilt = Subgraph_DSMA.Arrays[2];
SCFloatArrayRef RMS = Subgraph_DSMA.Arrays[3];
int Period = Input_Period.GetInt();
float StdDevs = Input_StdDevs.GetFloat();
SCFloatArrayRef DataArray = sc.BaseData[Input_Data.GetInputDataIndex()];
// Initialize filter coefficients
a1 = expf(-1.414f * 3.14159f / (0.5f * (float)Period));
b1 = 2.0f * a1 * cosf(1.414f * 180.0f / (0.5f * (float)Period));
c2 = b1;
c3 = -a1 * a1;
c1 = 1.0f - c2 - c3;
// Compute Zeros
Zeros[sc.Index] = DataArray[sc.Index] - DataArray[sc.Index - 2];
// Apply Super Smoother Filter
Filt[sc.Index] = c1 * (Zeros[sc.Index] + Zeros[sc.Index - 1]) / 2.0f
+ c2 * Filt[sc.Index - 1]
+ c3 * Filt[sc.Index - 2];
// Compute RMS over the Period
float sumSquares = 0.0f;
for (int i = 0; i < Period; ++i)
sumSquares += Filt[sc.Index - i] * Filt[sc.Index - i];
RMS[sc.Index] = sqrtf(sumSquares / (float)Period);
// Rescale filter in terms of Standard Deviations
if (RMS[sc.Index] != 0.0f)
ScaledFilt[sc.Index] = Filt[sc.Index] / RMS[sc.Index];
else
ScaledFilt[sc.Index] = 0.0f;
// Compute DSMA
float alpha1 = fabsf(ScaledFilt[sc.Index]) * StdDevs / (float)Period;
Subgraph_DSMA[sc.Index] = alpha1 * DataArray[sc.Index] + (1.0f - alpha1) * Subgraph_DSMA[sc.Index - 1];
Date Time Of Last Edit: 2024-12-28 14:19:31
attachmentEhlers DSMA.pdf - Attached On 2024-12-28 14:11:49 UTC - Size: 275.46 KB - 359 views
[2025-10-17 18:28:01]
User411320 - Posts: 376
was this ever created for sierra? I don't see it
[2025-10-17 19:03:29]
John - SC Support - Posts: 47903
This is not one of the built-in studies in Sierra Chart.
