Date/Time: Tue, 22 Apr 2025 14:44:10 +0000
chart intraday continious
View Count: 571
[2025-01-03 08:02:01] |
User914828 - Posts: 28 |
the problem is still
[2025-01-03 08:09:08] |
Sierra_Chart Engineering - Posts: 19305 |
Change the Continuous Contract option setting to "Date Rule Rollover": Continuous Futures Contract Charts: Continuous Futures Contract Rollover Options Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-03 08:11:40] |
https://www.sierrachart.com/image.php?Image=1735891873849.png
[2025-01-03 08:12:27] |
https://www.sierrachart.com/image.php?Image=1735891937274.png
[2025-01-03 14:41:44] |
Do not use the Continuous Contract option you are. Set it to "Date Based Rollover" only. Do not use the Volume Based rollover and do not use Back Adjusted either. Do not use any of those options. Also who is your futures broker? You should not be using CQG but instead Teton order routing. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-03 14:59:12] |
AMP FUTURES
[2025-01-03 17:48:03] |
We do not know why you are using CQG. If you are only trading the CME Group of markets, have Amp move you to Teton order routing: Sierra Chart Teton Futures Order Routing Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-06 10:59:37] |
ok, thank you for help, problem is resolved
[2025-01-06 20:11:05] |
https://www.sierrachart.com/image.php?Image=1736194237672.png
[2025-01-06 20:25:38] |
Who is your broker and clearing firm for your Teton Order Routing Service?
[2025-01-06 20:33:00] |
ok, i set AMP and is ok
[2025-01-14 20:34:27] |
The better use historical chart for daily data or Intraday Chart Only ?
[2025-01-15 15:34:35] |
It depends on what you want. If you want to control the specific session times that define a day, then use an "Intraday Only Chart". If you want the daily data as the exchange sends the information for a day, then use an "Historical Chart".
