Date/Time: Fri, 14 Mar 2025 12:30:34 +0000
Background color for DOM Price scale
View Count: 120
[2024-12-27 17:01:41]
ElDuderino - Posts: 17
Is there a way to make the background of the Price column in the Trade DOM different than the DOM background?
[2024-12-27 18:39:36]
John - SC Support - Posts: 38653
There is not a direct way to change the background of just the Price Ladder for the Trade Window (or on a Chart). For the Trade Window, however, there is the ability to change the general background to what you want, and then change the Buy/Sell and any other column backgrounds to be something else. This will get you what you want, with the exception that the space to the left will be the same color as the price ladder background.
Keep in mind that to do this, you need to disable the options for "Trade DOM Ask Background" and "Trade DOM Bid Background".
