Date/Time: Tue, 22 Apr 2025 23:32:29 +0000
Visualize Daily Change % On The Chart
View Count: 379
[2024-12-26 21:47:19]
User448728 - Posts: 25
Dear SC Team
How can I display the daily change in percentage (using the study: Add Additional Symbol) on my chart?
Using the ES, NQ, YM and RTY.
[2024-12-26 21:57:08]
John - SC Support - Posts: 39428
You have us confused by the mention of the "Add Additional Symbol" study. What exactly are you wanting to see/do?
[2024-12-26 22:06:25]
Is it possible to display the symbols which I mentioned above with the daily change in percentage?
[2024-12-27 05:58:01]
Please have a look at the attached Screenshot
attachmentChartImage.bmp - Attached On 2024-12-27 05:57:29 UTC - Size: 927.27 KB - 164 views
[2024-12-27 15:03:34]
You would need to use the Spreadsheet Study to have access to the various data and then you would need to determine where you want to set the basis point for the data and adjust the data for each symbol to that basis point. Then you can adjust the data as you want and eventually display the information as you want it from the Spreadsheet Study. Refer to the following:
Using the Spreadsheet Study
[2024-12-27 18:24:19]
I have found out that it works with the Percent Change Since Open Study, too.
Can you please tell me how to set the y axis correctly for ES, NQ, YM and RTY?
attachmentChartImage.bmp - Attached On 2024-12-27 18:24:04 UTC - Size: 927.27 KB - 161 views
[2024-12-27 18:46:00]
This is why we pointed you to the Spreadsheet Study to start with. Since you are wanting all the symbols to start at the same place (0% at the open) you need to adjust each data set to give you what you are wanting.
[2024-12-28 11:42:29]
I'm not sure if the offset function is correct
Date Time Of Last Edit: 2024-12-30 10:18:32
Private File
[2024-12-30 14:02:00]
AC7303484 - Posts: 28
You can do it with the percent change since open study.
I also added color bar alert based on above/below 0 so I could easily identify the makeup of what indexes are up vs down or if they are all in alignment.
imageScreenshot 2024-12-30 075751.png / V - Attached On 2024-12-30 14:01:00 UTC - Size: 37.72 KB - 53 views
[2024-12-30 14:09:59]
Sawtooth - Posts: 4209
Here's another way:
https://www.sawtoothtrade.com/free-stuff-6.html
