Date/Time: Wed, 12 Mar 2025 04:48:37 +0000
How to install certain study
View Count: 140
[2024-12-26 21:37:49]
User810128 - Posts: 3
Hello, I am trying to install a Murrey Math indicator study to my chart (link below). I followed the instructions and placed the file in the correct data folder. But when I attempt to add the study through the Chart Studies pop up, the Murrey Math indicator does not appear in the available list. I also tried adding as custom study. Any suggestions? Thank you.
Murrey Math
[2024-12-26 21:44:06]
John - SC Support - Posts: 38598
We do not understand what you are referring to in terms of "I followed the instructions and placed the file in the correct data folder." This is one of our studies, so there is nothing to install.
You should be able to add this as a regular study (not a Custom Study) through the "Analysis >> Studies" window. Refer to the following:
Chart Studies: Adding/Modifying Chart Studies
[2024-12-26 21:56:08]
Thank you very much sir, I think your response has saved me a couple hours of time as a new user.
