Date/Time: Fri, 20 Sep 2024 02:41:38 +0000
Enhancement request
View Count: 902
[2014-09-15 15:18:57] |
GCAdmin - Posts: 35 |
One of our users had the following request. Please let us know if this is something that can already be done with SC. With a horizontal line, if you enable price labels and put it on the left of the line, it will always show the price regardless of how far in the future you go. If you do the same thing with the price retracement tool, the price will only stay persistent if you extend lines to the left. It would be nice if you didn't have to extend lines left to have the benefit of persistent price labels. Thanks! |
[2014-09-15 18:32:04] |
This is not supported and will not be added because it does not make sense to us.
