Date/Time: Wed, 12 Mar 2025 04:53:45 +0000
Add Additional Symbol ES, NQ, YM and RTY wrong tick size
View Count: 212
[2024-12-26 07:25:09]
User448728 - Posts: 25
Dear SC Team,
The chart is showing the wrong tick size for NQ, YM and RTY.
[2024-12-26 14:38:37]
Sierra_Chart Engineering - Posts: 18750
You will need to adjust the Price Multiplier Input:
Add Additional Symbol: Price Multipler
[2024-12-26 14:46:01]
Please have a look at the attached Screenshot
ES > 0.25
NQ > 0.25
YM > 1.00
RTY> 0.10
How can I configure the settings correctly?
imageScreenshot 2024-12-26 153715.png / V - Attached On 2024-12-26 14:38:03 UTC - Size: 67.4 KB - 49 views
[2024-12-26 14:49:29]
Those are correct.
Refer to post #3 above. Most likely you are referring to a Price Multiplier issue.
Date Time Of Last Edit: 2024-12-26 14:49:54
[2024-12-26 15:07:22]
Study Settings for Add Additional Symbol:
ES > Price Multiplier > 0.01 > Value Format 0.01 (displayed correctly on the chart)
NQ > Price Multiplier > 0.01 > Value Format 0.01 (displayed correctly on the chart)
YM > Price Multiplier > 0.10 > Value Format 1.00
RTY> Price Multiplier > 0.01 > Value Format 0.01 (displayed correctly on the chart)
