Date/Time: Tue, 06 Oct 2026 12:47:17 +0000
Market Data / Depth Requests “Not Allowed” via DTC Client
View Count: 3859
[2024-12-26 00:56:31]
User990777 - Posts: 17
Hi Support,
Good day to you.
I can see my DOM with data and depth in the main SC without problems.
However, when I try to use a local DTC client (written in Python, communicating via Protobuf) to request market data for
GCG25_FUT_CME, I get:
error message :
Got MarketDataReject for SymbolID=1, Reason='Market data request not allowed'
Got MarketDataReject for SymbolID=2, Reason='Market depth request not allowed'
Below is a summary of my setup:
1) In my Main instance -> Global Setting >> Sierra Chart Server Settings >> Encoding >> "Google Protocol Buffers"
2) Sierra Chart DTC Protocol Server is enabled at 127.0.0.1:11099.
I’m sending:
EncodingRequest (Protobuf) → success (LogonResponse = LOGON_SUCCESS).
MarketDataRequest (type 101) and MarketDepthRequest (type 102) for symbol GCG25_FUT_CME, exchange set to either "CME" or "COMEX".
3) In Message Log
2024-12-26 00:33:37.063 | Software version: 2725 64-bit
2024-12-26 00:33:37.063 | Primary Thread ID: 12344
2024-12-26 00:33:37.064 | Usage end date: 2025-01-24
2024-12-26 00:33:37.064 | Enabled for: Advanced Features 2.
2024-12-26 00:33:37.064 | Enabled for: Sierra Chart Historical Data Service.
2024-12-26 00:33:37.064 | Enabled for: Denali Real-Time Exchange Data Feed.
2024-12-26 00:33:37.064 | Enabled for: Delayed Denali Exchange Data Feed.
2024-12-26 00:33:37.064 | Enabled for exchange2: COMEX
2024-12-26 00:33:37.064 | Allow Support for Sierra Chart Data Feeds is enabled.
2024-12-26 00:33:37.064 | Current selected Data/Trading service: Teton CME Order Routing
2024-12-26 00:33:37.064 | Custom symbol settings values: enabled
2024-12-26 00:33:37.064 | Chart Update Interval: 500
2024-12-26 00:33:37.064 | Intraday Data Storage Time Unit: 0
2024-12-26 00:33:37.064 | Time Zone: +00:00:00 (UTC+00)
2024-12-26 00:33:37.064 | 2024-12-26 00:33:37 Local computer time in UTC
2024-12-26 00:33:37.064 | 2024-12-26 00:33:37 Local computer time in SC Time Zone
2024-12-26 00:33:37.064 | 2024-12-26 00:29:44 Server time in UTC
2024-12-26 00:33:37.064 | Local computer UTC time and Server UTC time difference: 0 seconds.
2024-12-26 00:33:37.064 | Program path: C:\SierraChart\
2024-12-26 00:33:37.064 | Data Files path: C:\SierraChart\Data\
2024-12-26 00:33:37.064 | OS Version Number: 10.0
2024-12-26 00:33:37.064 | Locale Setting: C
2024-12-26 00:33:37.064 | DLLs: UserContributedStudies_64.dll
2024-12-26 00:33:37.064 | Allowed protected custom studies:
2024-12-26 00:33:37.064 | Crash reporter started: true
2024-12-26 00:34:19.130 | DTC Protocol server | Incoming connection from 127.0.0.1.
2024-12-26 00:34:19.130 | DTC client #6. 127.0.0.1 (5) | Creating socket.
2024-12-26 00:34:19.130 | DTC client #6. 127.0.0.1 (5) | New receive buffer size: 262144
2024-12-26 00:34:19.130 | DTC client #6. 127.0.0.1 (5) | Allocated send buffers: 32 of 131072 bytes.
2024-12-26 00:34:19.130 | DTC client #6. 127.0.0.1 | Unexpected DTC encoding request: 1413743386
2024-12-26 00:34:19.132 | DTC client #6. 127.0.0.1 | Requested heartbeat interval: 10
2024-12-26 00:34:19.132 | DTC client #6. Python DTC Client. 127.0.0.1 | Received logon request.
2024-12-26 00:34:19.132 | DTC client #6. Python DTC Client. 127.0.0.1 | Sent successful Logon response message to client. Username: . Result text: Connected to SC DTC Protocol server. Service=sc_futures_direct.dtc.trading|SymbolSettings=sc_futures_direct.dtc.trading
Log also shows lines like “Unexpected DTC encoding request: 1413743386” but still responds with Protobuf encoding and a successful logon.
4)
I see “Market data request not allowed” and “Market depth request not allowed” for that symbol.
Questions:
Is there any additional setting I need to enable so that external DTC clients can receive GCG25_FUT_CME real-time data/depth?
Many thanks in advance.
[2024-12-26 01:23:59]
Sierra_Chart Engineering - Posts: 25070
Refer to:
Data and Trading Communications (DTC) Protocol Server: Restrictions
[2024-12-26 04:17:31]
Thank you for the clarification. I’m trying to confirm if the restriction on “It is not possible to access real-time or historical data from the CME Group … from the DTC Protocol server” also applies when I am on the same PC where Sierra Chart is installed, using 127.0.0.1 (localhost) for purely personal (non-redistributive) use.
Could you confirm that, even though it is the exact same computer with no third-party access, the DTC Protocol Server still cannot provide me real-time CME data?
I just want to be sure I understand the policy correctly. Thank you for any further clarification.
[2024-12-26 07:18:06]
Yes absolutely it does also apply. Access cannot be allowed.
Date Time Of Last Edit: 2024-12-26 07:18:31
