Date/Time: Fri, 20 Sep 2024 02:52:50 +0000
Unable to Adjust Attached Orders
View Count: 1768
[2014-09-15 13:56:57] |
User21113 - Posts: 62 |
Hi, Have not observed this in paper trading. Have experienced this in live trading. In chart trading, created a limit order to buy with attached orders, sell limit and sell stop. The buy went through to the broker. The attached orders were able to be selected on the chart and dragged but they would not stay set at their new level. The confirmations is off. |
[2014-09-15 14:13:57] |
User38117 - Posts: 11 |
I don't know if I have similar problem. I can't even place orders getting error message below. Trade Order Error - OEC order update (Rejected). Text: All TimeInForce fields must be equal.. Internal Order ID: 1911. Service Order ID: OECFIX:635463253889695434:770. Symbol: NQZ4 | 2014-09-15 16:12:01 * Before this I run your update 1187. From now on I can't place orders via Sierrachart. It happens in Live and Demo version. Date Time Of Last Edit: 2014-09-15 14:14:47
[2014-09-15 14:34:48] |
This works correctly now.
[2014-09-15 17:01:45] |
Trade Order Error - OEC order update (Rejected). Text: All TimeInForce fields must be equal.. Internal Order ID: 1911. Service Order ID: OECFIX:635463253889695434:770. Symbol: NQZ4 | 2014-09-15 16:12:01 * For this, disable Global Settings >> General Trade Settings >> Use Server-Side OCO and Bracket Orders. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
