Date/Time: Mon, 28 Sep 2026 20:03:52 +0000
BUG in SCString::operator
View Count: 546
[2024-12-24 10:35:15]
User346098 - Posts: 50
Hello, the operator meaning here is reversed '>' instead of how it is documented '<'
while debugging I see:
strcmp(StringToCompare, InternalString) StringToCompare should have the Rhs of < but it gets assigned the value from the Left Hand side of the '<' operator.
Cheers.
[2024-12-24 13:49:13]
Sierra_Chart Engineering - Posts: 24997
Yes we see what you mean. The less than functions on SCString are never used by Sierra Chart internally. So they never were tested.
We will correct this.
Date Time Of Last Edit: 2024-12-24 13:49:32
