Date/Time: Tue, 22 Apr 2025 13:48:23 +0000
show my graphing tools on all my charts
View Count: 219
[2024-12-23 19:13:49] |
Zeek1804 - Posts: 1 |
Hello, thank you things have been working. Is there a way to show my graphing tools on all my charts?
[2024-12-23 22:04:46] |
We need to know what "graphing tools" you are specifically referring to.
[2025-01-11 17:37:05] |
Ali Al salehi - Posts: 3 |
its not giving me the option to change the colour of my rectangle tool that i drew on any idea how i could solve this problem
Attachment Deleted. Private File ![]() |
[2025-01-11 18:18:28] |
Sierra_Chart Engineering - Posts: 19305 |
Update Sierra Chart to the current version: Software Download: Fast Update After that, go to Global Settings >> Customize Chart Drawing Menu, and add the menu commands that you need. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-11 22:57:24] |
Still not working it's not giving the option to put the colours on or give me the option to show the prices
[2025-01-12 23:26:01] |
Go to Global Settings >> Customize Chart Drawing Menu. Press on the Use Default button. Press OK. After that, add or remove the menu commands as needed through Global Settings >> Customize Chart Drawing Menu. There should not be any problem with this. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-12 23:28:54
