Date/Time: Mon, 15 Jun 2026 03:39:48 +0000
CHART T P O
View Count: 814
[2024-12-23 19:09:51]
User612401 - Posts: 11
Hello
Can we put a volume profile in a TPO chart.If so, how to proceed?
Thank you
Good day and happy new year’s parties.
[2024-12-23 19:10:19]
John - SC Support - Posts: 46668
Refer to the following:
Time Price Opportunity (TPO) Profile Charts: Displaying Volume Profiles
[2024-12-25 07:56:30]
Hello John
Thank you for your reply
Put me I was talking about a global volume profile that encompasses every day in one volume.
There are many of us who have blocked this issue.
Thank you and have a good day.
Bruno
[2024-12-25 20:01:44]
Sierra_Chart Engineering - Posts: 24024
You can do what you want and it is explained here:
Volume By Price Study: 30 Minute Volume Profile at End of TPO Profile Chart
You can set it to cover any Number of Days you want.
Date Time Of Last Edit: 2024-12-25 20:02:03
[2024-12-25 20:35:25]
Thank you I will try to find.
[2024-12-26 08:02:29]
Hello
I have another question: can we import levels drawn from one contract to another at the time of rollower?
Thank you
[2024-12-26 16:23:55]
We are not certain of what you mean by "import". You can view drawings from one contract to the next by having those drawings updated at the time of rollover, or by updating them later. Refer to the following:
Changing to a New Futures Contract Month: Allowing Lines and Other Chart Drawings From Other Contract Months to Appear on the Current Contract
[2024-12-26 18:39:37]
Good evening
Ex: on a ESZ4 chart I draw horizontal lines when the rollower comes I open a new chart ESH5 how to import the lines I drew from ESZ4 to ESH5 because at the rollawer all the tracing work is lost.
Thank you
[2024-12-26 19:27:06]
User719512 - Posts: 442
Curious User612401 why you create a new chart for the roll rather than use the Chart | Perform Futures Symbol Rollover menu option which will update all open charts.
[2024-12-26 19:41:35]
If you are opening a new chart instead of rolling over - as User719512 asks, then you would need to use the following to draw the drawings on the new chart:
Chart Settings: Copy Chart Drawings from Chart #'s (Chart >> Chart Settings >> Chart Drawings menu)
But, as pointed out, the better way is to rollover, in which case refer to the instructions linked to in post #7.
[2024-12-27 20:09:03]
Good evening
Thank you I will try to achieve this.
Thank you and have a good evening.
Bruno
