Date/Time: Sun, 04 Oct 2026 13:37:36 +0000
Alert Manager Alerts Log Order
View Count: 1734
| [2014-09-15 12:41:24] |
| Futures Operator - Posts: 239 |
Please consider adding the ability to set the alerts log to show/sort the latest alerts at the top, so one doesn't have to manually scroll down to find what alert has triggered. This would be especially useful when alert pop ups which take control of the mouse are disabled.
| [2014-09-15 16:56:57] |
We do not understand why you are asking this. This already exists. Look at the Sort menu. We would think this should be extremely obvious being the sort menu is right at the top. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2014-09-15 16:58:46
| [2014-09-15 18:21:30] |
Excellent, did not realize it was there, thank you for pointing me to it. Just FYI, it was not extremely obvious as it is different than the method to sort on the Symbol/Time Alerts tabs, which is a click on the column headers. Date Time Of Last Edit: 2014-09-15 22:22:06
| [2014-09-15 23:13:05] |
OK, we see. However, also for the Symbol and Time Alerts tabs you can also use the Sort menu as well. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
