Date/Time: Tue, 22 Apr 2025 18:14:13 +0000
not getting options data
View Count: 207
[2024-12-23 17:51:17] |
Rnn - Posts: 56 |
Hi, I'm not able to get ESH25-CME options for some reason - pressing on get options but nothing is loading, usually it takes 5-10 secs and its fine but can't load it today for some reason ESZ24-CME options were loading fine last week Date Time Of Last Edit: 2024-12-23 17:52:15
[2024-12-23 20:05:33] |
Rnn - Posts: 56 |
its ok now
[2024-12-23 20:08:04] |
Sierra_Chart Engineering - Posts: 19305 |
This should now be resolved.
[2024-12-24 01:15:16] |
user_xyz - Posts: 467 |
Two questions related to this. 1 - Anyway to add a search field or even sort by the headings (Symbol, Description or Expiration)? it's a ROYAL pain scrolling through 10,000+ contracts to find the one we are looking for. 2 - If we pay for CFE can we get access to SPX options data, I don't see that in the list? |
[2024-12-24 21:01:08] |
1. We will add this capability. 2. No. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-01-06 10:45:33] |
Rnn - Posts: 56 |
can u pls sort it by date of expiration - much easier to locate the right option instead of searching the huge data by the symbol the one that expires today is first, tomorrow next and so on.. thanks |
[2025-01-06 18:04:35] |
Yes, we will look at adding a sorting option.
