Date/Time: Fri, 14 Mar 2025 11:13:45 +0000
Break-Even keyboard shortcut
View Count: 103
[2024-12-23 15:33:11] |
BigBagel - Posts: 69 |
Is there a way to change the break-even offset for the hotkey?
[2024-12-23 16:22:02] |
John - SC Support - Posts: 38653 |
When selecting "Move to Break Even" using any method, it is going to use the "Move to BE Offset" that is set in the Trade Window for that chart. Refer to the following: Basic Trading and the Trade Window: Set >> Move to BE Offset The "Move to BE Offset" is saved with the "Trade Configurations", so you can setup different configurations to have different offsets and select the different configurations with a Control Bar or Keyboard Shortcut. Refer to the following: Basic Trading and the Trade Window: Using and Changing Between Different Trade Window and Attached Orders Configurations For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
