Date/Time: Fri, 20 Sep 2024 02:34:04 +0000
EURAUD
View Count: 921
[2014-09-15 11:48:53] |
ripsdips - Posts: 143 |
Is there an issue with EURAUD? charts wont load, getting error message. I sent log in
[2014-09-15 18:26:33] |
What is the error message? Post the Message Log here. Here are the instructions: https://www.sierrachart.com/index.php?page=PostingInformation.php#log Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, *change* to the Teton service: Sierra Chart Teton Futures Order Routing |
[2014-09-15 18:29:32] |
No, I figured it out. It had to do with too many days being loaded on the renko.
