Date/Time: Fri, 14 Mar 2025 12:22:10 +0000
[Programming Help] - unable to download data
View Count: 95
[2024-12-23 13:21:07] |
Chris J - Posts: 2 |
when i open my charts i get a message in an orange box saying requested symbol was not found and a red box saying Download Failed Error downloading historical intraday data for ESZ24-CME the symbol is unknown to the server
[2024-12-23 13:34:46] |
Sierra_Chart Engineering - Posts: 18778 |
We see you have Sierra Chart set to use CQG and that is not a CQG symbol. Translate the symbols following the instructions here: Edit Menu: Edit >> Translate Symbols To Current Service Did you want to use CQG? If so, you do not have any exchanges active and you will not receive data. To access historical and streaming market data independent from your Trading service. Follow these instructions.
Set "Global Settings >> Data/Trade Service Settings >> Current Selected Service" to "SC Data-All Services". Press "OK" And then translate the symbols in your Chartbooks and Sierra Chart using this "Edit' menu command: Edit Menu: Edit >> Translate Symbols To Current Service (Translate Symbols to Current Service) You can then use the data provided by Sierra Chart independent of your trading service. We recommend that you follow the instructions above for now. At this time you will be receiving delayed streaming data. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-12-23 13:39:13
[2024-12-23 13:52:36] |
ok but i have been live trading for the passed week with the CQG data no problems, are you saying that if i am connected to SC Data i will be able to trade as normal as CQG is what i am set up for trading with with my broker AMP
[2024-12-23 14:02:10] |
In this case, keep Sierra Chart set to use CQG. Translate the symbols following the instructions here: Edit Menu: Edit >> Translate Symbols To Current Service And activate the exchanges that you need here: https://www.sierrachart.com/UserControlPanel.php?page=DenaliDataFeed Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
