Date/Time: Mon, 14 Apr 2025 01:46:46 +0000
[Sticky] [Locked] - Important Notice - Resolving: No trade accounts assigned
View Count: 939
[2024-12-23 06:42:34]
Sierra_Chart Engineering - Posts: 19166
All of the Teton trading accounts that are associated with the broker Stage 5 or GFF, and use the clearing firm Dorman have been moved to a separate iLink connection over the weekend.
When using Teton order routing and you get the error "No trade accounts assigned" , then do the following:
Select Global Settings >> Data/Trade Service Settings >> Main Settings.
Set the Clearing Firm to Dorman/Stage 5 or Advantage/Stage 5 (In older versions of Sierra Chart).
Press OK.
Select File >> Connect to Data Feed.
Date Time Of Last Edit: 2024-12-23 14:57:30
