Date/Time: Fri, 14 Mar 2025 10:43:06 +0000
Daily chart on gold isn't matching other platforms. Not printing correctly
View Count: 116
[2024-12-22 20:43:52]
ebaza02 - Posts: 1
Daily chart on gold future chart is not appearing correctly. It is not printing correctly compared to other platforms.
imagesierra help.PNG / V - Attached On 2024-12-22 20:42:50 UTC - Size: 109.31 KB - 34 views
[2024-12-22 21:18:37]
Sierra_Chart Engineering - Posts: 18778
Assuming you are referring to XAUUSD it looks correct for us:
https://www.sierrachart.com/image.php?Image=1734902305300.png
Re-download all the data in the chart by going to the chart and selecting "Edit >> Delete All Data and Download" from the main Sierra Chart menu. You just need to do this once per symbol and not for each chart. This command is on the main Sierra Chart menu at the top. Only use it from that location.
