Date/Time: Mon, 15 Dec 2025 09:11:42 +0000
EUREX exchange connection options in 2025
View Count: 486
| [2024-12-22 10:17:55] |
| User192240 - Posts: 3 |
Hello, happy Denali/Teton user here for CME group products. Thank you for superb service! I would also like to connect EUREX exchange in 2025. Here indication EUREX were planned to be part of Teton Sierra Chart Teton Futures Order Routing: Introduction Here support indicates it will never will be Unable to trade EUREX via Teton | Post: 381602 Should I 1. Use alternative connection like Rithmic for EUREX? 2. Wait longer until EUREX get integrated into Teton. Will it be? Please, advise. |
| [2024-12-22 18:49:53] |
| Sierra_Chart Engineering - Posts: 21843 |
1. Definitively do not use Rithmic for EUREX. The only recommendation is to use CQG for EUREX. 2. There are no plans for this now. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
| [2025-01-03 17:38:22] |
1.I should specified that intention is to use Denali Market Data for EUREX not from Rithmic 2.Since Teton order routing service doesn't support EUREX it's fine to use Rithmic for routing and market data from Sierra Chart? |
| [2025-01-03 17:49:48] |
1, 2. Do not use Rithmic for any live trading. Please do not use Rithmic at all. It is an unreliable choice. We do not want you as a customer of Sierra Chart if you are using Rithmic. Use CQG or Interactive Brokers only for EUREX. As a matter of fact we are going to remove EUREX symbols for Rithmic, and post a notice we are going to have that done by the end of January. We are terminating any support for EUREX through Rithmic. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-01-03 17:49:55
