Date/Time: Tue, 22 Apr 2025 23:08:10 +0000
Copying study settings
View Count: 296
[2024-12-21 22:57:16] |
User925540 - Posts: 62 |
Hi I have multiple studies that are common between multiple study collections, if I decided to edit the settings of those studies I need to update them in every study collection manually. Is there a way to copy/paste study settings? Or maybe edit them through text (where I can copy/paste the settings)? Thanks. |
[2024-12-22 04:27:51] |
Sierra_Chart Engineering - Posts: 19305 |
No there is not: Is there a way to copy/paste study settings? Or maybe edit them through text (where I can copy/paste the settings)?
[2024-12-22 16:58:57] |
Thanks. Would you be doing something in that area? Would be great to have configs in general in a readable format so that the user can edit/copy/duplicate easily. Almost all files are compiled and cannot be read/edited. Would be really great and would resolve many inconveniencies if those were readable/editable: KeyboardShortcuts.config Sierra.config *.StdyCollct *.twconfig The only one that is currently readable and editable are the symbol lists, making it very easy to edit watchlists and copy/edit/update them across installation instances: *.SymbolList |
[2024-12-23 13:41:17] |
No, there are definitively no changes that will ever happen with this. Sierra Chart is designed for performance, and never would we be using textbased files for storing settings.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-12-23 13:41:32
[2024-12-24 01:24:25] |
Doesn't have to be of any impact to performance. It can be something that can be exported into a text based format, modified/copied then imported again (if needed) into the compiled format that you are referring to as a source of a better performance. It just gives ton of flexibility for reading/moving/editing/duplicating which aligns with the SC brand that is providing flexibility to the users to do/customize whatever they want. |
