Date/Time: Wed, 12 Mar 2025 04:50:25 +0000
Space wasting windows plus delete alerts
View Count: 180
[2024-12-21 02:42:16] |
User472677 - Posts: 362 |
1.When sc starts it automatically brings message log and alert manager windows. How to disable these windows from automatically starting? 2. How can an alert that was previously set be deleted? 3. Where can one place where all pricee alerts that are set can be seen excluding alerts from chart studies? |
[2024-12-23 14:38:14] |
John - SC Support - Posts: 38598 |
1. Those windows will not automatically open when start Sierra Chart except for two possible reasons: - They were open when you exited from Sierra Chart. - An alert occurred at the time you opened Sierra Chart, and there was some important message in the Message Log 2. You have to find the alert and disable or delete it. The alert itself will give you the information for where it is coming from. 3. On the "Alert Manager" is a tab for "[Symbol Alert]". This has just the Symbol Alerts where you can view, modify, and delete the symbol alerts. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-24 05:55:16] |
User906935 - Posts: 2 |
The problem is that U have studies in chart that paint different colors on charts based on alerts. So when I close alert windows and message lig they pop up immediately again. If I minimize them, they open themselves. I have limited space on my laptop. These windows are a great nuisance and i do not need them. Please suggest a solution.
[2024-12-24 13:17:44] |
Sawtooth - Posts: 4182 |
Grab a corner of the alert window, and drag it to make the window very small, then park the window somewhere non-intrusive.
