Date/Time: Tue, 22 Apr 2025 23:11:28 +0000
Region Dividing Line
View Count: 215
[2024-12-20 16:47:39]
User914828 - Posts: 28
I have problem with region dividing line, is not enable.
imageZrzut ekranu 2024-12-20 122237.png / V - Attached On 2024-12-20 16:42:53 UTC - Size: 32.96 KB - 49 views
[2024-12-20 16:51:55]
John - SC Support - Posts: 39428
Refer to the following setting:
Chart Settings: Display Region Dividing Lines (Chart >> Chart Settings >> Grid menu)
[2024-12-21 07:30:33]
I have it set up, but it still doesn't work
imageZrzut ekranu 2024-12-21 082741.png / V - Attached On 2024-12-21 07:28:54 UTC - Size: 38.83 KB - 39 views
[2024-12-21 19:02:13]
Sierra_Chart Engineering - Posts: 19305
Make sure you are setting the color of the Region Dividing Line in the correct Graphics Settings Window:
Graphics Settings: Introduction
Provide an image of the chart or Trade DOM, by following these *exact* instructions:
Date Time Of Last Edit: 2024-12-21 19:03:22
