Date/Time: Wed, 27 Nov 2024 14:32:18 +0000
TPO Prices
View Count: 1181
[2014-09-15 06:41:38]
User67305 - Posts: 16
Hi, i have TPO chart up for 6EZ4 and on 9-12-14 the high is showing 1.2989 and when i look at a 30 min candle chart the high is showing 1.2981 and i can't figure out why this is. The lows are off same amount also. Thanks, Paul ....
[2014-09-15 10:02:59]
What is the Letter/ Block Price Increment in Ticks study input set to?
[2014-09-15 17:49:32]
set to 1
[2014-09-15 19:13:18]
this is really upsetting, the charts are useless being like this.
[2014-09-15 19:44:17]
Post an image of the TPO Profile Chart by following these instructions:
[2014-09-15 19:48:49]
http://www.sierrachart.com/image.php?l=1410810495140.png
[2014-09-15 19:49:59]
http://www.sierrachart.com/image.php?l=1410810593630.png
[2014-09-15 19:51:05]
I looked back over the past week and none of the days past high or lows match between TPO and candle chart
[2014-09-15 19:51:34]
i am using same hours on both, 8 am to 5 pm EST
[2014-09-15 19:56:48]
also both are on Dec Z month
[2014-09-15 20:08:10]
This is correct:
We get the same thing. You can confirm with the exchange.
So there is something about the candlestick chart that is not right. Post an image of that.
[2014-09-15 20:09:13]
We see you already posted an image of the candlestick chart.
What you need to do is enable Chart >> Show Rollover Dates.
For September 12, the chart is going to be showing the September contract since it is a continuous futures contract chart. This is the reason for the difference.
Date Time Of Last Edit: 2014-09-15 20:11:05
[2014-09-15 20:20:08]
wow, that seems to be the problem, settings on candle rollover were not same as tpo, been pulling my hair out on this !! Ok thanks for looking and finding the problem. Paul....
