Date/Time: Sat, 19 Sep 2026 05:24:23 +0000
“Text Config” (Global Settings) **stopped working** correctly since last Updates...
View Count: 530
| [2024-12-20 10:44:18] |
| Rainer - Posts: 112 |
Since last update (Sunday Dec16.2024; incl. 2720) the usual Right-Click on Text and select from user pre-defined Text-Config list of 8 = no longer is functioning correctly ... The user’s pre-defined TEXT+COLOR+FONT is still programmed (remains) in the Global/Tool/Text Config ((or right-click on text /Chart_Drawing_Properties/Text Properties’Dialog Box)) ..see attached pic … BUT when recall (click on) any of the 8-configs in the list, ONLY the COLOR & FONT & FONT’size are recalled **BUT NOT** the actual user'pre-defined **TEXT** … iow. it is not functioning "as per usual" and does not recall (auto-populate) upon onChart-Text change with right-click and select any of the list of 8-configs (user'pre-defined) Texts. .. when manually load/check in Text’Properties Config, and flip between Tabs [Config]&[Settings] menu (Tabs) .. it does load and keep the retained TEXT+COLOR+FONT+size, from the list of 8-configs, it just does not populate on chart when/with right-click select any list'of'8 of config'ed.Texts. Currently running 2 instances of SC on PC, after both update last Sunday the same above phenomenon/problem appeared on both SC instances. |
| [2024-12-22 06:53:12] |
| Sierra_Chart Engineering - Posts: 24890 |
Update to version 2725. Instructions: Software Download: Fast Update And, check this specific setting in Global Settings >> Tool Settings: Applying Tool Configuration to Existing Drawing Updates Text:Yes Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2024-12-22 06:54:59
