Date/Time: Wed, 12 Mar 2025 05:09:27 +0000
replay feature extremely choppy
View Count: 272
[2024-12-20 03:45:12]
User606716 - Posts: 6
I have used the replay feature successfully for several months but it would never work smoothly if I went back more than 60 days. Now if I go back more than 3 days it is so choppy it is unusable. I don't think I changed anything. Please advise.
[2024-12-20 15:06:30]
John - SC Support - Posts: 38598
Are you replaying multiple charts or one chart? What Replay Mode are you using?
[2024-12-21 00:15:34]
I am only replaying MNQ but I have 4 charts with different time frames. Even when I set it to single chart it doesn't help. I am in Standard Replay mode.
[2024-12-23 14:33:01]
Check your intraday data storage time unit, as this would affect how the data loads if it is not set to "1 tick":
Data/Trade Service Settings: Intraday Data Storage Time Unit (Global Settings >> Data/Trade Service Settings >> Common Settings >> Common Settings)
[2024-12-24 02:37:42]
The intraday data storage time unit is set to 1 tick.
[2024-12-24 08:21:04]
Sierra_Chart Engineering - Posts: 18750
In the case of a Continuous Futures Contract, make sure you know what contract month you are replaying:
Continuous Futures Contract Charts: Displaying Rollover Transition Times and Contract Months
It may be an inactive Contract month.
[2024-12-26 20:55:34]
I switched to continuous futures contract-date rule rollover and this seems to have solved the problem. Thank you for your help!
