Date/Time: Wed, 27 Nov 2024 15:34:19 +0000
[User Discussion] - Auto Trade entry price
View Count: 1366
[2014-09-15 00:51:26]
User11734 - Posts: 9
hi - I am using the spreadsheet auto-trade feature with rules for entry on cell K3 . I have all the signals working correctly, and the exact time when a trade should trigger, and it seems to work as expected. However, the entry price is always the close of the current or previous bar on the chart. I know the exact entry price and got it to show on a spreadsheet column (i would like it to be one tick above signal bar) but could not find documentation on how to set it. The only example that's available, is for a crossover of the EMA. How do I set it to trade a stop order one tick above a given signal bar? thank you!
[2014-09-15 10:15:23]
This is not controllable.
Refer to the documentation here for about how orders are filled during a replay.
http://www.sierrachart.com/index.php?page=doc/doc_TradeSimulation.php#TradeSimulationBidAskPrices
When an order is submitted, it will be filled based upon the most latest trade, bid and ask prices.
Date Time Of Last Edit: 2014-09-15 10:16:20
[2014-09-15 13:17:59]
Sawtooth - Posts: 4120
You can use cells J22 and J24 to set a Stop Entry price, then set J71 and J73 to 'S'.
Date Time Of Last Edit: 2014-09-15 13:34:33
[2014-09-15 15:05:28]
tomgilb, i tried that idea with J22 and J71 - what do you out in J22? something like =K4 would work? (i can put the entry value in another column)
[2014-09-15 15:46:57]
Yes, =K4 would probably work.
But since you only need one price value, you could put the formula directly in J22.
Also, column J cells are not affected by a Yes setting of Signal Only On Bar Close, so if you want an intrabar trigger, reference row 3, and if you want a close-of-bar trigger, reference row 4.
I like to use an IF statement, like this:
=IF(conditions,C4+J21,0)
that only offers a price when conditions are met.
Date Time Of Last Edit: 2014-09-15 16:18:17
[2014-09-21 00:07:33]
I've tried setting J22 to the value as suggested, but it seems like the fill values are almost randomly set..
I even see the all green arrows pointing correctly to the signal bar, but the fill is incorrect.
To simplify, I tried a trivial K3=c3<c4 and J22=c4+0.25, just to see what it does with a simple example, and it seems to almost always pick the entry price at the close of the current bar. (this example calls for a Stop-limit order of previous bar plus a tick, whenever a bar high is less than previous bar high)
any ideas??
[2014-09-21 03:09:50]
If you want a buy limit order 1 tick above the high of the previous bar at the close of the current bar, try this:
-Set 'Signal Only On Bar Close' to Yes
-in cell K3:
=C3>C4
-in cell J22:
=IF(C4>C5,C5+J21,0)
