Date/Time: Tue, 22 Apr 2025 23:16:47 +0000
Remove order entry line
View Count: 154
[2024-12-19 20:22:16]
User310898 - Posts: 43
Hi is it possible to remove the green order entry line ONLY as highlighted in the attached but KEEP the limit/stop lines for use (red lines).
Thanks!
imageremove green line only.png / V - Attached On 2024-12-19 20:20:53 UTC - Size: 24.91 KB - 45 views
[2024-12-19 21:16:29]
John - SC Support - Posts: 39428
There is not a way to do this.
[2024-12-20 04:44:34]
Tony - Posts: 565
As John said, it cannot be removed, my get-around is:
1, set some fill space on the right of the chart,
2, Chart -> Chart Settings -> Trading -> Visual -> Trade Drawings Left Align %
Set it to a small number i.e. 5, that way, we kind of "remove" it from the chart, but sometimes I still need to know where my entry is, I have to use a custom study just to draw a short dash line showing my entry level around last few candle bars.
Date Time Of Last Edit: 2024-12-20 04:45:16
