Date/Time: Tue, 15 Apr 2025 12:36:16 +0000
Micro E-mini S&P 500 MESH5
View Count: 315
[2024-12-19 18:32:13] |
User381072 - Posts: 5 |
CME Group' to 'Micro E-mini S&P 500 MESH5' -------------------------------------------------------------------------------- Hello, I am trying to trade the MESH5 but the tick value is $12.5 instead of $1.25. Is there any config ? Can you help me please Regards |
[2024-12-19 18:39:53] |
John - SC Support - Posts: 39274 |
The "Currency Value per Tick" is set in "Chart >> Chart Settings >> Symbol". But you should have the correct value if MES is the symbol for the chart. Are you using a different symbol (ES) and setting MES as the "Trade and Current Quote Symbol"? If so, then refer to the following: Chart Settings: Updating Currency Value per Tick for Trade Symbol For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-19 21:04:32] |
Hello, I set "Currency Value per Tick" to $1.25. It was $12.5. Thank you very much best regards |
[2025-02-21 12:40:46] |
Hello, I have two account with TopStep, When I trade with the first account, I can see the orders and positions on the chart and DOM but when I switch to the second, I can see them only in the DOM. Is there any config to show them also in th chart ? It's important for me to keep the same thing. Thanks in advance |
[2025-02-21 13:51:04] |
Sierra_Chart Engineering - Posts: 19226 |
Refer to: Chart Trading and the Chart DOM: Viewing Orders and Trade Position on the Chart / Trade DOM Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-21 14:21:15] |
Hello, As you can see in the screenshot, All the configurations are in place but I can not see orders and positions when i switch between my two accounts. Could you tkae the time to help me please. Thanks |
![]() Attachment Deleted. |
[2025-02-21 14:34:28] |
We gave you a link to the documentation because it explains this subject thoroughly. Those are not the only settings. There is the Symbol and Trade Account of the chart. You need to set those to match. Once again refer to: Chart Trading and the Chart DOM: Viewing Orders and Trade Position on the Chart / Trade DOM See step 3. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-04-09 12:59:37] |
Hello, I am using topstep as propfirm and I have a question. Is there any way to control my risk and set limits that protect my downside, stick to the plan and always trade for tomorrow. Thanks in advance. |
[2025-04-09 15:08:54] |
Refer to the following: Global Profit/Loss Management -- Please post new questions in a new thread. Do not continue to ask unrelated questions in this same thread. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
