Date/Time: Tue, 22 Apr 2025 23:11:29 +0000
TOPIX/MINI TOPIX and OSAKA EXCHANGE SYMBOLS
View Count: 148
[2024-12-19 17:59:28]
User624595 - Posts: 243
Where can they be found under find symbols, and under what exchange?
[2024-12-19 18:14:23]
John - SC Support - Posts: 39428
We do not have data for these.
If they are available through your broker, then you would need enter the appropriate symbol in the "Selected Symbol" field on the Find Symbol window.
[2024-12-19 18:19:54]
IB has data. How can I find the appropriate symbols in Find Symbols? Nothing shows up if search TOPIX.
Date Time Of Last Edit: 2024-12-19 18:20:15
[2024-12-19 18:37:45]
It will not be in Find Symbols. You need to check with Interactive Brokers for the symbol you would need to use for it.
[2024-12-20 16:25:34]
Is it possible to add historical data for these, Topix and Nikkei in Japan on OSE? It is available on many other sites/platforms, they are popular markets.
[2024-12-20 16:28:29]
We do not have the data.
You would need to get it from the same source you are getting the real-time data.
