Date/Time: Tue, 22 Apr 2025 22:43:04 +0000
Spreadsheet Trading
View Count: 144
[2024-12-19 17:43:21] |
User644833 - Posts: 18 |
Hello support team, My conditions work perfectly in cells K3 and M3. If the condition to open a position (value in cell 1), the trades are executed correctly. Sometimes, however, it happens that a position is opened with the opening of a new candle without the condition being fulfilled or ((value in cell 0). I have noticed that this effect may occur when the market is very fast. This happens to me in replay and in live trading. Is there a solution or does Sierrachart have problems here? |
[2024-12-19 17:48:48] |
John - SC Support - Posts: 39428 |
When this is occurring the value in the cell is changing to 1 and then back to 0. So you are just not seeing that it was true at that time. If this is not what you want, then you would have to look into what exactly you would want to change to modify this behavior. Be aware of the option for "Signal Only on Bar Close". Refer to the following: Spreadsheet Systems, Alerts and Automated Trading: Signal Only on Bar Close (Signal Only On Bar Close (Columns K, M) | Signal Only On Bar Close (Columns L, N-Z)) For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
