Date/Time: Thu, 06 Feb 2025 05:09:07 +0000
Study collection Errors
View Count: 1142
[2014-09-14 22:53:08]
abrown8703 - Posts: 64
SC, the Bollinger Band study collection that I use now produces a message:
This study collection file requires a newer version of Sierra Chart. To update select Help >> Download Current Version or Prerelease. | 2014-09-14 18:42:13 *
I have updated, error message still shows and study does not display.
Please Advise.
[2014-09-15 10:10:56]
Attach it here so we can test it. Here are the instructions:
https://www.sierrachart.com/index.php?page=PostingInformation.php#AttachFile
[2014-09-15 12:20:56]
I foolishly named my study collection "Bollinger Band." By renaming it, the issue was solved.
[2014-09-15 12:30:56]
This issue has resurfaced. See attached chartbook.
Date Time Of Last Edit: 2014-09-15 18:17:31
attachmentRange.StdyCollct - Attached On 2014-09-15 12:33:14 UTC - Size: 28 KB - 375 views
[2014-09-15 13:52:31]
N!co - Posts: 140
I have the same problem
error : This study collection file requires a newer version of Sierra Chart. To update select Help >> Download Current Version or Prerelease
attached is the study collection
attachmenterror.StdyCollct - Attached On 2014-09-15 13:52:23 UTC - Size: 55.9 KB - 499 views
[2014-09-15 17:38:02]
We are looking into this problem.
[2014-09-15 18:17:03]
We should have this problem corrected in a few hours.
[2014-09-15 20:11:44]
This problem is now resolved.
Update Sierra Chart by selecting Help >> Download Prerelease. Let us know if you have any further issues.
[2020-04-16 18:07:54]
User691948 - Posts: 3
This issue happens to me also. While loading some older stdycollct files, error message: This study collection file requires a newer version of Sierra Chart. To update select Help >> Download Current Version or Prerelease.
However recently created stdycollct files do load OK. Try both 64bit and 32bit program gives the same error. Running program version 2086 64-bit (30839M)
Attached are stdycollct files that give error.
attachment$Volume Only.StdyCollct - Attached On 2020-04-16 18:00:28 UTC - Size: 5.3 KB - 345 views
attachmentMACD Crossing.StdyCollct - Attached On 2020-04-16 18:05:06 UTC - Size: 22.82 KB - 311 views
[2020-04-16 18:36:16]
We will check on this.
[2020-04-16 19:34:31]
We can confirm that those Study Collections are not compatible with newer versions of Sierra Chart. You will need to open those in version 2056 or earlier and save them again and then you can use them in newer versions.
Are any of these obtained from the Sierra Chart website? If so, we will make sure they are up-to-date.
Instructions to install a previous version:
Software Download: Software Rollback Procedure
Date Time Of Last Edit: 2020-04-16 19:36:37
