Date/Time: Tue, 22 Apr 2025 23:14:05 +0000
huh? after reboot, Sierra now starts with Instance 2 !
View Count: 136
[2024-12-19 06:37:40]
User59879 - Posts: 77
After a reboot and Windows upgrade this morning, Sierra now suddenly starts with Instance 2, instead of the main instance
it skips launching the master instance, and instance 2 is (of course) waiting to connect to the server (server is not there)
and there is only one instance visible in the icons, so the main instance is really not running
how can I fix this?
[2024-12-19 06:43:41]
Sierra_Chart Engineering - Posts: 19305
Go to this folder on your system through the File Explorer.
C:\SierraChart\
Run the Sierra Chart executable from there.
We also see this installation you have:
C:\SierraChart\SierraChartInstance_2\SierraChartInstance_2\
This path does not make sense. Remove this installation in that last subfolder.
Date Time Of Last Edit: 2024-12-19 06:43:59
[2024-12-19 06:45:34]
fixed, thank you for your speedy response and help!
