Date/Time: Mon, 21 Apr 2025 13:08:35 +0000
[Locked] - Christmas Gifts
View Count: 2630
[2024-12-19 04:09:03]
Sierra_Chart Engineering - Posts: 19285
Christmas gifts, for this season:
1. The ability to edit study identifiers manually. Released in version 2724.
2. The ability to customize the colors of window title bars and borders.
3. Reliable Binance data feed (already released). Although the Binance data feed, is poorly designed and has been a lot of trouble, with enough effort and also adding more threads of execution we have been able to make this reliable now.
For the main Binance connection we had to use about 24 threads. This data is then normalized into the DTC protocol, and when it is transmitted to the US, there are no disconnection issues, and only a single thread is used to process the data. The DTC protocol is superefficient. And Sierra Chart's send and receive buffer management in Sierra Chart implemented network communication, guarantees high transfer rates and no disconnections. Absolutely superior what Sierra Chart has. Binance is very very substandard.
4. Settings to control the visibility of Chart Drawings from drawing Tools based upon time frames of the chart bars.
Not everything is going to necessarily be done before Christmas, but as soon as possible.
Date Time Of Last Edit: 2024-12-23 15:04:01
[2024-12-24 22:42:51]
We thought we could do this:
We cannot. The operating system, ultimately is not letting an application properly control this. There is inconsistent behavior that is outside of our control. And there are unknowns like the position of the System menu, minimize, maximize and close button boxes.
The only possibility is for Sierra Chart to completely implement, a title bar. And the minimize, maximize and close buttons, and window move functionality but this is a lot of work. We will do this at some point but we do not know when we will get to it.
Date Time Of Last Edit: 2024-12-25 00:40:29
[2025-02-26 08:42:38]
This is now available in the latest version. Initial documentation:
Controlling Visibility of Chart Drawings on Different Chart Bar Time Frames
Update: You need to update to Sierra Chart version 2744 for this functionality.
The documentation above has been completed and improved upon.
Date Time Of Last Edit: 2025-03-01 20:50:18
