Date/Time: Tue, 22 Apr 2025 22:56:43 +0000
[User Discussion] - Sierra Chart, Teton, and AMP Futures
View Count: 177
[2024-12-19 01:53:27]
ElDuderino - Posts: 17
Please provide clarification on how I connect with AMP Futures to live trade from Sierra Chart (Package 11). At the Sierra end I have Denali for data and Teton for order routing. At the AMP end, my Live Trading Credentials shows "Current Data Enabled" as "CQG". (This is how I had it set for using another trading platform.)
To live trade my AMP account from Sierra Chart, am I correct in assuming that I would need to change my credentials to support this scenario at the AMP end: (a) do not provide data, as I would be getting it from Denali and (b) use Teton for order routing.
Specifically, here are the relevant options for updating the datafeed section of my AMP trading credentials:
CQG
Teton (Sierra Chart)
CQG (No Data - Order Routing Only)
Sierra Chart - Denali - CQG (No Data - Order Routing only)
I believe my current selection of CQG means that AMP uses CQG for both data feed and order routing. Am I correct in assuming that selecting the "Teton" option will result in the desired (a) do not provide data feed, and (b)use Teton for order routing?
Thank you for your time, attention and patience!
[2024-12-19 02:15:01]
Sierra_Chart Engineering - Posts: 19305
Yes this is correct:
