Date/Time: Fri, 14 Mar 2025 12:19:14 +0000
How do I change the bar spacing specifically for numbers bars
View Count: 249
[2024-12-18 16:05:00]
User893675 - Posts: 1
Hi Sierra Chart,
How do I change the bar spacing specifically for numbers bars? I want to increase the spacing between the footprint charts, so I can fit a normal
candlestick bar as well as a volume profile, in between the footprint values. Is there a way I can achieve that?
The reason i want to do so is because if I put in the number bars study, the volume profile study is less visible.
Thanks.
Date Time Of Last Edit: 2024-12-18 16:09:26
[2024-12-18 16:43:11]
John - SC Support - Posts: 38653
We understand the question about the candlestick. There are a few options for this.
- Refer to the following and 4 Inputs below it:
Numbers Bars: Open and Close Marker Style
- You can overlay the <Main Price Graph> back onto a Numbers Bars chart in order to get the candlestick showing. The trick on this is that you will want to set the Candlestick Width Percent to be very narrow so the candlestick will fit in between the number or the columns (depending on what you have displayed). Refer to the following:
Study/Price Overlay Study
Graphics Settings: Candlestick Width % (Global Settings >> Graphics Settings >> Other)
Graphics Settings: Using Different Color and Graphics Settings for Specific Charts
We are not sure what you are looking for in terms of the Volume Profile. There is not a way to "fit" a volume profile in between the Numbers Bars. The Numbers Bars themselves give you the ability to view a Volume Profile, so you should be using those options.
[2024-12-21 06:29:51]
lmahonefutures - Posts: 11
So I'm not sure if this is what he's talking about, but I too had to same question. If there is a way to space the number bar from the right. Would this be right side fill space or a different setting. My goal is to see the numbers bars and volume profile values, even if it means cutting off the closest numnbers bar to the far right since we cant display deltas in the chart trade dom yet.
imageCapture.PNG / V - Attached On 2024-12-21 06:28:06 UTC - Size: 340.5 KB - 34 views
[2024-12-23 14:39:50]
In order to have space on the right, you would use the "Lock Fill Space" option. Refer to the following:
Working With Charts: Right Side Fill Space
