Date/Time: Tue, 22 Apr 2025 22:48:36 +0000
Continuous Contrace
View Count: 181
[2024-12-17 20:50:39]
User312718 - Posts: 26
Good afternoon,
My broker is Stonex and I have Sierra version 2416. Would you be able to guide me as to how to set up a continuous contract?
Thank you in advance for your time!
MB
[2024-12-17 21:18:22]
John - SC Support - Posts: 39428
The instructions for setting up a Continuous Contract are at the following link:
Continuous Futures Contract Charts
But given how far back you are with the release, we can not say if everything will work for you. Offhand, we think it should, but just be aware that if there is an issue, then we can not help with a release that far back.
[2024-12-18 18:41:16]
Should I update to a more recent version?
[2024-12-18 23:13:31]
More recent versions do not have support for StoneX (Gain Capital). So we assume you are on that version for that reason.
But, you will eventually have to update, at which point you will have to decide whether to change brokers or trading systems, as we do not have support for StoneX and we do not plan on adding it back in.
