Date/Time: Wed, 23 Apr 2025 03:19:22 +0000
How to apply all settings and indicators from one chart to another
View Count: 332
[2024-12-17 17:12:18] |
User333599 - Posts: 9 |
Dear Team, I would appreciate some help in transferring all the settings and research indicators from one chart to another for a different commodity. Could you guide me through the process? |
[2024-12-17 18:07:22] |
John - SC Support - Posts: 39428 |
The easiest way to do this is to duplicate the chart and then change the symbol. Refer to the following: Using Chart Templates: Duplicating Charts / Template Charts Otherwise, to get the same studies, you could use a Study Collection. Refer to the following: Study Collections For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-17 18:43:30] |
I recently copied a chart and changed the trading asset, but now the chart is blank as shown in the attached image. https://www.sierrachart.com/image.php?Image=1734460945799.png |
Attachment Deleted. |
[2024-12-17 18:53:22] |
Refer to the following: Intraday Chart or Chart Bars Not Updating | Blank Intraday Chart | "Currently no data to display" message for Intraday Chart For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
