Date/Time: Fri, 20 Sep 2024 02:44:00 +0000
Error while " Import and load intraday data"
View Count: 1043
[2014-09-14 08:37:09] |
turnbull - Posts: 34 |
Hi, I have been importing data ( EDIT> Import and load intraday data) from Tickdata.com without any problems. Today I am not able to do it and there is an error in the log attached. Please help |
Error.txt - Attached On 2014-09-14 08:35:35 UTC - Size: 703 B - 426 views |
[2014-09-14 19:00:25] |
This problem has now been solved. Update Sierra Chart with Help >> Download Prerelease.
