Date/Time: Wed, 23 Apr 2025 03:09:20 +0000
Define bar thickness by volume
View Count: 175
[2024-12-17 14:22:27] |
User367161 - Posts: 19 |
I have succeeded in coloring High/Low bars according to their delta. Now I would like to define the bar "thickness" by volume (best percentage) I have seen that on "somebodys templates" page (don't remember where). So I think it's doable. If so, how and where can I set the width (not the bar spacing) according to a 1 or two days average volume of one bar. At the moment I use 1r or 2r bars. Best regards, Hendrik |
[2024-12-17 14:23:26] |
... sorry, forgot the screen shot: https://www.sierrachart.com/image.php?Image=1734445058502.png |
[2024-12-17 14:24:31] |
... and more: I'm not comfortable with "Large Trades Indicator"
[2024-12-17 16:18:50] |
John - SC Support - Posts: 39428 |
We are not certain what you are looking for, but refer to the following Graph Draw Type and the 2 types below it: Graph Draw Types: Price Volume Bars For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2024-12-18 14:45:37] |
Thank you I'll look into it
